1 - 4 of 4 Posts
I have a 2000 Ford focus ZTS with a 5 speed manual transmission. The issue I am having, is when you are going down the highway at speed and you let off the throttle it pulls to the left. When you get back on the throttle it pulls to the right.
I just got the car and it has all new tie rod ends, stab links, ball joints. I have installed new calipers and brakes, new struts and torqued everything under the front end on both sides... I can see the away bar bushings look cracked. I have also put new tires and had an alignment done.. I am not to sure what to look for with the control arm bushings?? Is there something I can do to check them?
1 - 4 of 4 Posts
