hi there i have an issue with my car 1.6 petrol 2006
the engine check light came on the fault codes are p1632 and p0444 found the p0444 the purge valve wire has been cut?! so thats sorted the p1632 reffers to the smart charge system so changed alternator hopefully this is sorted but however I have a problem with the temprature, the speedo cluster needle shows around the 80 degree mark however when I run the speedo through test mode the temp shows around 120-130 degrees!! the fan dosent kick in and the engine smells really hot? the fan tries to run slightly when the interior heater 4 stage switch is turn on with the ac button on but then runs real slow not cooling down the car. I have a feeling the ecu is the problem I would really appricate so help if anyone can.
Thank you from sunny old england! [cheers].
heres a picture of the car on start up the temp reaches the 120-130c after a min or two
