1 - 8 of 8 Posts
focus bolt patter 4x108 ???
when buying after market rims does it matter what offset to get???
...sorry to ask these q's but i'm just making sure. thanks
Discussion Starter · #4 ·
alright....thankya much
Discussion Starter · #6 ·
aight, thanks y'all. pc
H&Rzx3 said:
focus bolt patter 4x108 ??? when buying after market rims does it matter what offset to get???
My rims - installed a few days ago - had "double-drilling" - 4 and 5 hole patterns (nine holes total). This make the rims easier to sell later - because few car have 4x108 pattern. The holes are covered by a hub cap.
My 16" rims on SVT have 45mm offset. These wheels protrude slightly firm wheel well and decrease vertical clearance between tire and front fender lip. Wish they were closer to OEM 49mm offset.
i have 17x7's with a 40 offset and they fit perfect. technically not possible to install without rubbing but with my 2 inch drop i have no problem at all. and thats with hard cornering just ask around and possibly have the rim and tire fitted to check out clearances and wheel well gaps and such. good luck. ideally you want 42 and higher though
1 - 8 of 8 Posts
