1 - 3 of 3 Posts
Hi,
Just replaced the blower resistor. Positions 1 to 3 work, not 4. Resistor is pretty hot to touch. Could problem with 4 be related to temperator of resistor?
How hot is normal for that resistor?
Thanks
The resistor will run quite hot, which is why it is located in the airstream of the HVAC system. When only position 4 works, it suggests the resistor pack is bad. When position 4 works, and some of the other positions do not, it suggests a problem with the blower switch.
Thanks, I will go that direction. The confusing thing is that the thermal fuse went on the new resistor. Luckily I found an equivalent? at Radio Shack for $1.69, rated for 142 C or 288 f, same color scheme as the one from Ford. I am about to try it again.
1 - 3 of 3 Posts
