hi there helping fellows.
again here for some help.
my focus 2002, 2.0 split port, sohc started stalling and looses power at the point that engine stops even when driving. symptoms start after 10-15min the car first starts in the morning. i can still drive it but you know.... and i have no other car and need the car for the everyday family duties.
a friend of mine has a focus same as mine that parts couldnt sell so i get things for cheap. that focus is a sohc too and was involved in an acident so nothing wrong with the engine.
things done so far.
1. replaced the catalytic converter
2. replaced spark plugs (new) wires and ignition coil pack (his)
3. replaced air and fuel filter (new)
4. dpfe changed (his)
5.tried to check the vacuum lines from the dpfe to the egr valve and they look fine (or i dont know how to check em)
is there a way i can test the solenoid and the egr valve ?
im wishing that wont be needed to change the fuel pump and i really need some help from you guys to see whats up.
p.s.what kind of obd2 scanner for the ford can i buy without spending much ???
pls pls help
thanks guys
things done so far.
pls pls help
thanks guys
