2002 Ford Focus SE Zetec
Automatic transmission
158000 miles
It was driving beautifully and then just died in the middle of the road after I came to a stop. Cranks and cranks but no start.
1) Air:
no obvious obstruction, I'm pretty sure there's no obstruction.
2) Spark:
It's got spark. I checked with an inline spark tester and got spark in at least 1st and 2nd cylinders, didn't see the need to check the others.
3) Fuel:
It's got half tank of gasoline. It's definitely priming the lines with 2 second hum from the fuel pump when turned to on. The lines are definitely under pressure and spilled fuel when I opened the line as I turned key to on. The fuel cut off switch is definitely not open since I pressed on it many times and has 12V when hot. I sprayed some starting fluid and seems to want to,sputter to a start, but doesn't.
4) timing:
belt definitely turning and not broken.
5) compression: can't imagine I would lose compression suddenly.
So I was able to pull two codes, p0913 and p1233. One is the fuel rail pressure sensor and the other one is fuel pump driver module offline. So I went to a Pick-N-Pull and replaced the fuel rail pressure sensor and the module from a 2002 wrecked car, so they are used parts but still no luck. Checked all fuses and all good. Also swapped relay with the high beam, but didn't load test the relay. PID showing fuel pressure at 90 psi.
Interestingly, I pulled all plugs and see them bone dry, not fouled by fuel. And now my battery is dying from all the cranking. Btw, fuel filter changed last month.
I'm frustrated, is there anything here that's indicative of a bad fuel pump?? Damn this returnless electronic fuel system! If you need all the PIDs when being cranked in order to diagnose it, let me know.
I hate to see this car go, but it's one problem after another, I just changed the alternator, 2nd one in 3 years.
158000 miles
1) Air:
2) Spark:
3) Fuel:
4) timing:
