401 - 420 of 1376 Posts
Anyone have a video of the emergency braking light yet?
Also, which option? There is three IIRC. without, with and with w/ hazards.
My tablet died as I was working on it in the car lol.... Will have to wait until it charges.
What do you mean with "what happened"? Now I can run aftermarket HIDs without resistors and relay, and it works perfect!
Was finally able to get my heated mirrors and puddle lamps enabled. This was finally possible after discovering this thread and purchasing a couple of door modules that allow for heat and puddle lamp capability. $80 at Tasca.
Focus Preacher
I already have the heat (winter package) but for the puddle lamps, is it really worth it?
I was thinking of that earlier...
I think i need a new mirror assembly for the puddle lamps...
Le bump.
Gentlemen,
Is there an option to enable Sirius?
I thought I seen it in there... But even if, you'd probably need a/the antenna.
Le bump.
Well no Video, but hazards = your hazard (orange) lights will Flash too when doing an emergency break. Wit emeregncy brake light flashing - your brake lights simply Flash. without - nothing Special, your break light is on, just like when you normally brake.
got my usb ELM and just enabled "Global open/close", works like a charm!
Gonna look thru all the options.
I don't have many to play with since I have Titatium.
tried to enable brake light flashing with no luck, got engine light on instead, :(
P.S. Cleared all trouble codes using Forscan, engine light went off.
So I might be dumb but I checked my BCM and it says i already have Hillstart assist, yet my settings doesn't give an option, it just shows traction control and my rear parking aid. Does this mean its always on, or do i need to to do something to have it show up?
Also I updated the BCM to have global open/close, and it worked just fine.
Probably always on...
With the DCT it's always enabled as it's required as the driver of an automatic does not expect the car to roll backwards on a hill. Although if you don't hold the brake long enough or release the brake for more than 2-3 seconds it will cut the clutch back in and roll backwards just like a manual.
Only the ST in the North American market came with a selectable hill launch assist or hill start assist in the instrument panel display, although in Europe and in the FOcccus tool can activate the brake assist in the ABS system.
Okay…so on this site after I type in my vin http://ford.xtlt.ru/ab/
It says that I have the heated mirror, but I don't actually see anything
in my car that says where that would be. Unless I"m missing something.
More than likely I'm confused. I "speed-read" all 42 pages.
I have noticed that my rpm/speedo gauge has some unused lights
on it. I definitely want to get the HillAssist.
Also, do I just need to get this http://www.amazon.es/ELM327-interfaz-diagnóstico-escáner-coche/dp/B00FPG3ZUQ/ref=sr_1_4?ie=UTF8&qid=1402757046&sr=8-4&keywords=elm327
or do I also need the OBD2 kajiger?
Heated mirrors are tied into the rear defrost element. Look on your side mirrors, if there is a symbol with a mirror and 3 wavy lines going through it then you have heated mirrors, or just look behind the mirror.
And that elm327 cable is all you need.
Cool, thanks for clarifying.
I found a video from ford that explains the heated mirror thing.
https://www.youtube.com/watch?v=86pxxRHQf2U
Its basically what Ox-y-GenIII said, but it also shows you the location.
Alright cool, thank you.
Other part is, I don't understand what you are talking about by hi bus and low bus and med bus etc..
Also, is everyone preferring the bluetooth over wired?
Does it work on mac?
