1 - 3 of 3 Posts
Struggling to work out what this pipe for trailing from my drivers side rear wheel. It doesn't appear to be attached at either end so I'm assuming it's a discharge pipe from somewhere. But for what?
305154
Thats What She Said
Well since UK and from the pictures it woudl be the passnager side for the folks playing along in the US or in the left hand drive market.
Looks like someone may have replaced the hard plastic line that goes up to the gas cap area. there are two metal lines, the main fill, and then a over fill. there is then a plastic one that is part of an EVAP system which routes the EVAP from the charcoal canister solenoide up to the back of the gas cap area. Is that hose there? I will try to see if I can find a picture.
Not sure if the UK versions have the same EVAP systems....
Edit:
This is just the main fill, you can see it does not have the 3rd plastic line. so there should be 3 "tubes" going to the fuel cap.
1 - 3 of 3 Posts
