1 - 12 of 12 Posts
Turbo!!!!
My flywheel is covered under warrenty right?and if so should they be charging me labor on replacing the clutch at the same time?
what kind of problem are you experiencing?
Turbo!!!!
The dealer adjusted my shift linkage and two days later my clutch fried. The fly wheel did not crack ,but they said they can't resurface it because it's a two peice flywheel,so there going to replace it.I said the clutch frying was there fault ,because they must have screwed something up when they were working on it .They said the clutch just wore out ,but I had no problems until they worked on it.When I got the car back it felt like the revs were hanging more so than normal,but it turned out the clutch was hanging and not fully disengaging.
i would kill somebody and then write a letter to the nearest manager!!!
You could always contact the Better Business Bureau and see if they can help correct the dealerships mistake.
Focused Focus
How many miles are on your car? Theres a TSB on the flywheel causing premature clutch failure.
Turbo!!!!
about 37000 but i have the premeium care warrinty from ford.
Turbo!!!!
Discussion Starter #8
what does tsb stand for? can anyone help me with this situation?
Turbo!!!!
Discussion Starter #10
Thanks WD40.
Focused Focus
Technical Service Bullitin. Its covers the flywheel, clutch and possibly the trans itself.
Turbo!!!!
Discussion Starter #12
Does milage matter? I would have just done this myself if I didn't feel like 128 ford didn't screw it up when they had my car for two weeks just to end up adjusting the shift linkage.
1 - 12 of 12 Posts
