1 - 6 of 6 Posts
I now realize that this trans is based on a manual 6 speed. Reason for no fluid dipstick. Does this trans have a fill and/or drain plug in it? I can't see going 100K miles or whatever on the original fluid.
Sure, it has a drain plug and a fill plug. It only holds anout 2 quarts of fluid, so if you want to change it early it shouldn't be an expensive proposition.
Yeah they do Bill, and it works the same & uses the same fluid (2 qts of the Ford manual trans synthetic trans fluid) as the manuals do.
Drain bolt & fill plug, level should be near the plug when filled.
Thanks, appreciate it. Is the fluid Manual Trans Fluid, like what would go in a Tremec?
Nope. It's a special DCT fluid.
Motorcraft® Dual Clutch Transmission Fluid is specifically formulated for use in the DPS6 PowerShift twin dry-clutch transmission. It was designed as dual functioning fluid to protect gear, synchronizers and bearings, while also used to operate the transmission's shift mechanisms
Motorcraft® Dual Clutch Transmission Fluid is manufactured with synthetic base oils and performance additives providing improved shifting at all ambient temperatures. Protects against wear and corrosion, while low viscosity improves fuel economy
Use only in transmissions requiring a fluid meeting WSS-M2C200-D2
https://www.fcsdchemicalsandlubrica...ransmission Fluid&category=Transmission Fluid
Part number: XT-11-QDC
SWEET! Thanks
1 - 6 of 6 Posts
