Hey hey.
I want to get the LED lights that are white while they lights are solid, and amber when they flash. So it would be white as a driving light, but when I signal to turn they flash amber.
Since they're LEDs they will create the HYPERFLASH mode, no? You know.. where the blinker flashes at MACH5 speeds.
autolumination offers a flasher and a load balancer. The load equalizer splices right into the wire... but I already have the Halos spliced into the wire, and the car alarm is spliced in somewhere too. I just don't know if I want to cut into that same circuit AGAIN... much less if there will be any wire left if I do!
The flasher would plug in and simulate the right about of resistance to keep it from thinking a bulb is out. But from my searches -- I'm gathering that we don't have a signal flasher. Is this completely true? I know they're controlled by the hazard flasher... is that the same thing? Could I replace that with one of these LED flashers and get results? Am I way off?
Here's the link to the flashers/load equalizers.
Clicky!!
They look like the relays in the engine bay... and I think that's where the hazard relay is (right next to the relay that controls the fog lights to do the fog-light-mod).
Any ideas?
Do you think the halo LEDs along with LED "bulbs" in my turn signals would create enough resistance? Probably still no, huh?
