1 - 2 of 2 Posts
FF Affiliate
As many know the 2012-2018 has a issue with the Gas Tank collapsing and it is a very costly repair , I have seen tickets in the 1785.00 to 2400.00 range through Ford , I had my MK3 on the lift changing the oil and I found the Gas Tank on the bottom showing signs of it starting , I am testing taking the Vac to the EVAP loose and unplugging the electrical to the valve to see if that stops this from getting worse , in the photo you can see where I can get a thick bladed pry bar in between the Gas Tank and the strap , By unhooking the Vac line to the EVAP this will set a CEL Check Engine Light but that can be delt with easily with a Tune
1 - 2 of 2 Posts
