21 - 40 of 335 Posts
I'm almost hesitant to take my 2012 focus in now to get this software update done >.< My car has had loss of transmission engagement, no start, and lack of power issues plus excessive noise <grinding> since I purchased the vehicle brand new. I've had it into the dealership 4 or 5 times in the first couple years and they were never able to resolve the issue but I'm sure it was well documented.
From what I understand, this update will actually MAKE THE VEHICLE NOT DRIVABLE in an attempt to keep it from destroying itself if it does detect a problem right? This is a daily highway vehicle for me, 100mile drive, in an area with no cell service... if this thing decides to DOA on the road I'm really screwed. I think I'll take my chances with it giving up the ghost sometime in the future which will likely be very predictable <but will inevitably cost more to repair> rather than having the computer take over and stop me in the middle of the mountains in BFE.
Discussion Starter #22
I had not heard anything like that about the 15B22 TCM software update. To my (admittedly limited) knowledge, the software update for the TCM is to provide improved fault recording/fault reporting for troubleshooting and improved fault indication for the operator.
It would seem unlikely that Ford, or any car maker, would make a change that would immobilize the car, if only because of the liability issues that could present.
Wouldn't surprise me at all tbh. One user on the first page had the update done while in for a brake job and then had his vehicle basically immobilized and had to be towed back to shop. Without knowing WHAT that TCM update does exactly I'm very hesitant to get it. Forcing "limp mode" on a vehicle is a known practice in the diesel industry, only a matter of time until it's coded into gasoline engines as well.
I got a letter today about my 2012, which I traded in. The update should make a check engine light come on at the start of TCM problems, rather than the thing just failing.
Or like me they had my car since Wednesday morning until later this evening I got a call saying that they have to replace transmission control module (TCM) so much of a headache can't believe I'm going thru this with a brand new car never had this kind of problems with my used cars I had before.
Discussion Starter #26
"Limp Home" modes are incorporated in most US vehicles specifically because of liability issues, and according to the 2012 Focus owners manual exist for both engine and transmission malfunctions.
Field Service Actions are voluntary, so there is no reason to get it if you don't want it. Just make it clear during any dealer visit that you do not want this done, as many dealers do outstanding FSAs automatically.
For myself, I tend to try not to be an "early adopter" when it comes to things like this, simply because there are often bugs to be worked out. Are the recent reports of issues post-15B22 indicative of that? Are the issues experienced caused by 15B22, were they existing problems identified by the update to the software in 15B22, or were they merely an unfortunate coincidence? There's not enough information here to say for certain either way.
I haven't received a letter from Ford yet for either of our cars, but I understand that this program will run until sometime in July, 2016. Since I have no reason to take either car to the dealer at the moment, and after having the clutch packs replaced on both last spring have had no transmission issues at all, I'm in no hurry.
I don't think the issue is caused BY 15B22 unless your vehicle is indeed showing symptoms, like mine, and I'm simply not willing to take the chance of the new programming leaving me stranded on the highway out of cellular range, that's all.
Per Ford, it does not change the operability of the vehicle, it just gives you a warning when the TCM is not working optimally; before, you could have intermittent symptoms and never know it was the TCM's fault.
With the CEL, the codes would be stored, so no more dealers saying "We can't duplicate the issue." You will have proof that it's the TCM, not a bad ground or other issues.
I had the update done on my 2014 Focus and I really don't like it. It has changed so much on how the transmission worked before the update. I get more shuddering and shaking then what the car had before I had the update done along with the transmission jerks real hard during take off and it will throw you forward in your seat if your not ready for it. Also had to take it back to Ford because the update disabled the clock which Ford didn't know how to fix so after a few hours of screwing with it I was able to get the clock working right. So If I could I would like the update removed but I know I can't so I'll half to just live with it which it gonna really make me mad. So Ford in my opinion turned my DCT into a piece of crap. It was working beautiful with the new TCM and I go take it in and have this update put in and now my Focus sucks A##. Thanks Ford for making me unhappy with my Ford. I think I'll call Ford customer care and voice my dislike on this update.
I suspect more the the 15B22 update was applied when your car was serviced. I just had mine done and a software update to revise shift strategy was applied as well. I've noticed the same thing with more clutch chatter but have been told the software has to "relearn" the car's specific clutch touch points, etc. This process can take 100-500 miles, I guess.
I'm going to give Ford the provisional benefit of the doubt on this one. Major revisions were made to DCT workings for the 2015 model year and this could be applying some of those lessons to older models. The "adaptive" learning of the gearbox was one of the problems before, I think, and perhaps this will make things better. We'll see in a few hundred miles. I'd suggest confirming this with your dealer and giving it a little time, but like you I wanted a car but wound up with a project.
I bought my '14 Focus SE brand new in 09/14 (according to VIN is was built in 03/14). After driving it about 15,000 miles the transmission shaking/hesitation/slipping issues began. It only begins shaking after I've been driving it for minimum of 45 minutes, but it's very noticeable after that when in stop and go traffic, or at low speeds (under 10 mph). I've schedule an appointment with the dealer to get it looked at this Friday, so we'll see how they handle it. The 15B22 update is applicable to my VIN, so they might apply that too.
About a week ago, I noticed some slight stuttering at low speeds (4<x<12 mph), and some minor hesitancy in acceleration between 20-25mph. The hesitancy was more pronounced when I'm entering an on-ramp to get on the freeway. And today, I notice that there's an alert out for my VIN for this FSA. Issues at approximately 16.5k miles (brand new car with similar purchase and build date (I think) as NashFocus14).
I haven't received any Check Engine or other warning lights. I'm also not sure if my experience is related at all to what the FSA would address.
Timing is likely a coincidence, but I'm unsure on how to proceed based on feedback of the posts here.
EDIT: I saw the alert after I had logged into my Ford Owners account (nothing via USPS, so far).
Hi guys,
I'll be happy to look at some options from my end. Just PM me your VIN, mileage, best daytime phone number, full name, and dealer name/location.
Meagan
Had the front brakes done on Monday. During that service, they applied 15B22. I hadn't really noticed anything different. But today I went to drive it and the check engine light came on with "SERVICE TRANSMISSION" warning (or maybe "TRANSMISSION MALFUNCTION"... I forget the actual wording). The car wouldn't go into gear at all. I shut it off, and started it back up. Same error. Car would go into gear, but would not upshift until close to redline. Had it towed to the dealer and now waiting to see what's next. Hopefully it's just a software problem having to do with the 15B22 recall.
same thing has recently happened to my focus I connected my scan tool I got 3 different codes. what ended up being the problem
Hi guys,
Meagan
Thanks! I can send my info once I get home, but I'd be wary of applying any updates based on some of the responses to this thread :/ (At least until we get some positive results)
You had an issue with the update as well or was it one of the 3 different codes you had?
My car wont pass 30 & just redlines i havent got the software update yet wondering what caused your car to behave that way
Sounds that way to me, too. When I called to inquire about this I was told there is also an update the the TCM that affects the learning strategy.
I won't be able to drive mine much for the next few weeks - could you please keep us updated on how the "learning" process progresses? Thanks.
