I'll start with saying I'm a n00b to the Focus in general, but not a n00b to cars. It's an '04 2.3L ZX3 with around 95k miles. FWIW, I don't intend for this to be the quickest car straight line and I'm probably just about done with "go fast" mods, but I wouldn't mind it handling and looking slightly better. I'll start with the mods that the previous owner left me with:
Now a few questions...
1. My car has much less low-end torque than it does in the mid range or higher RPMs. I want to blame this on a lack of backpressure from the fart-can like exhaust. I was blaming it on the piping of the exhaust, but it's only 60mm (2.36") from what I can find online, but it may be because of the muffler that kit has as well. Regardless, I plan on changing this catback soon because it's too loud for my tastes. Do you think I can rekindle that low-end torque with 2.25" piping? Or will 2.5" piping be okay with a real (likely Borla) muffler?
2. I've got those Ford Racing Lowering springs and the ride is really bouncy. I haven't done a strut/shock bounce test, but I don't think they're blown. What kind of struts/shocks should I replace the OEMs with? I was thinking that maybe some SVT shocks may work since they're made for shorter springs than the ZX3, but I'd rather ask you guys than just make that assumption.
3. My car is difficult to get into gear at times (mostly 1st / Reverse). I did research and it says to check the fluid level and adjust the linkage. I'll do all that, but I wouldn't be shocked if it was because my clutch components are on their way out due to these symptoms and the mileage. I'm looking at clutches right now (Stage 1... I don't have huge aspirations with this car other than being a reliable, somewhat efficient, somewhat sporty daily driver)... any opinions?
Thanks in advance.
- FS Werks 2-piece CAI
- CFM TB
- Header
- HKS Hi Power Catback
- Massive Speed Lower Engine Mount Bushings
- Massive Speed Front and Rear Strut Bars
- Progress Rear Sway Bar (22mm I believe)
- Ford Racing Lowering Springs (1.5" drop)
Thanks in advance.
