yes i love that sound [
] it's completely normal unless it's a constant whistling, then you might have a leak. oh my bad was reading the wrong thing, i was just refering to the intake with the sound whistling
Thnx man, that's gonna be my next 'air flow' mod that i do. Wish me luck!2000blackzx3 said:Very easy install to do, takes less than an hour. Just be careful when removing and reinstalling the TPS.
i beleive from what i read, people stuck a rag in the hole before starting to dremel out the INTAKE MANIFOLD, then i guess they vaccumed up the shavings before removing the rag. Most use the gasket as a template on how much to shave away.psenechal said:Is dremeling out the intake required or is strictly a bolt-on? How do you keep the plastic from entering the intake if you're shaving it away with a dremel?
