1 - 2 of 2 Posts
2008 Ford Focus SE - 2.0L Duratec (4-spd auto) Vapor Silver
(North American Version )
______________________________________________________
The fan speed control knob/ dial Works on speed 1, 2, 3 and 4.
So naturally every speed you move to , the fan should go faster(eg.1-2-3-4)
Except in my car all of a sudden ....that changed.
When you turn the Dial speed-2 to speed-3, #3 stays at the same speed that #2 was, and if you increase to #4 it works as it should at max speed.
So basically all speeds work all speeds blow air & all speeds work as they should except #3....# operates at the same speed as #2 for some reason.
I've owned the car since new & it used to work properly...speed 3 would be faster than 2, but slower than 4.
I replaced the Blower Motor Resistor , but this made no difference.
My AC works completely fine. No check engine lights no issues that would cause interference.
All other Vent Controls/ Heating buttons work just fine.
Does anyone have any idea what's the cause & how i can fix this?
Likely blower switch if resistor did not fix it. Some like mine melt inside, too much current for the plastic used.
1 - 2 of 2 Posts
