1 - 7 of 7 Posts
Not sure if this is the right place for this.
i was wondering if it is possible to reverse the rotation of the factory fans and flip them to the other side of the radiator to make room for a turbo.
i dont have ac so the fans would go right on the radiator.
I used Merecedes fans on my Mustang. You can suck through the rad. or blow from the front, ..Just wire the fan the other way, and see if it pushes air hard, you can try it with jumpers at the connector.
I used aftermarket fans, I have one in the normal spot and the other on the opposite side of the radiator wired in pusher mode.
Be ye warned that they are NOT as efficient when wires as pushers.
1 - 7 of 7 Posts
