Last night after driving home and using defrost a little I noticed that after I turned the car off the fans remained on, and on high. I noticed and thought it was a little strange, but ended up going in and not thinking about it the rest of the night (I know some cars will have a fan run on LOW for a while sometimes). Came out this morning, dead battery. I hooked up jumper cables to my wife's car (2003 ZX3) and the fans kicked on as soon as I connected my car..... I could NOT get my car started! Even holding her RPM around 3K, my car didn't have enough to turn over! I SHOULD have checked how old the batter is but I haven't yet and now I'm at work without the car.
Let's start with the fan problem, is it safe to say it's R15, the high speed fan relay? I've pulled it found continuity between 2 of the 5 legs. Is there a diagram that tells what normal is and shows what should be what when testing it? Should I even test it or assume that IS the problem and just replace it?
As far as the battery / no start. Would the fan being on while it's trying to jump take enough to where the car won't turn over? I did notice it's a 70A relay.
Thanks in advance, I've been able to get SO much done with the help of this site!
Car: 2004 ZX5 Zetec 175K miles, I bought it in Sep with 173K [wrenchin][wrenchin]
