1 - 3 of 3 Posts
Sonic Mk3 Crew #03
Ok so with the turbo in place i realized the factory fans do not fit so here comes my question...
The right side with the 11 blades can still fit and be used I just need to cut the left side off.
This way I keep the Resistor and the 11 blade fan.
My question is when I wire the second fan the slim 2500cfm summit racing 16"
fan do I wire it like the other one with only the power?
Because the factory fans come on at the same time and use the resistor to speed up and slow down both fans depending on High speed signal or low speed signal.
I would like to keep one side of the fan assembly just because I know it flows 2500+ CFM at high speed and because it will still hold the resistor.
The slim fan fits between the intake housing of the turbo so that will go on the other side.
Any suggestions? Comments? or help would be appreciated. Because wiring is my main issue.
Shot me 3 deer!!!
i definitely don't know, but i would say yes, wire them up the same. i don't see whiy you couldnt
Sonic Mk3 Crew #03
Had a better look at the setup and its relatively simple one of the brain fart threads sorry guys
1 - 3 of 3 Posts
