1 - 4 of 4 Posts
Any help is greatly appreciated.
I have a 2000 ZX3, which runs great.
However, the fan (and a/c) no longer works. Nothing happens when I turn the knob. The first thing I checked was the fuses and everything is fine.
Thank you in advance.
U mean your cooling Fan or your Blower Motor fan.
When you turn the know you dont hear any air coming out or you just dont feel cold are coming out when you hit the A/C Button.
If you feel air coming out but not cold air then yes you have a A/C Concern.
If you dont hear the blower motor turning on at all then i would inspect that first.
I can run your VIN and tell you concern that others have with the same problem your having.
Thanks for your reply. When I turn the dial for the fan, from zero, nothing happens. I don't feel anything from the vents. Unfortunately, I don't even know where the blower motor is.
If you really want some more information just give me the word and ill pull all your information for you for your vehicle and that will surely help a bit more.
1 - 4 of 4 Posts
