1 - 6 of 6 Posts
Hello the other day my Rear Right Wheel Liner came off it has a Fabric feeling and i am looking for something to replace it...
The local dealer wants 60 bucks to replace it but does anyone know anything cheaper, i loooked all over google and cannot find one single thing
could use something like coroplast to make one.
or a auto wreckers will have one or should have one i think 00-07 use the same liner.
What is it that it is really called?
The front is a fender liner right?
Whats the back one's called?
rear wheel well liner is what i would call it.
if you go to the wreckers you can pull it yourself. if they are pulling it its probably better to get a new one at ford for $60. more so if thats with them installing it. (not sure if you meant the liner and install when you said to have ford replace it)
Will i be fine for awhile driving without one, i just replaced my tires because one blow out...so need to wait for next check
C2H5OH
As long as you don't go puddle jumping you'll be fine, or should be. If you look at the very back you'll see a black plastic box looking thing. That is the cabin vent. It has a rubber flap inside that vents pressure from the cabin to the outside. If you get into a lot of water you can push water into the hatch/trunk through that vent.
And I'd also say a JY is your best bet for a replacement.
1 - 6 of 6 Posts
