Well the F2 header is installed!
And before I say another word I have to thank MustangsandFocus' (Josh). Josh is new to the my area and a new FF member. Ladies and Gentleman I for one consider myself very lucky to have noticed that Josh lived close to me. I sent him a PM to say welcome and he responded with a little bit about himself and his automobile background. I can't even begin to scratch the surface of this mans knowledge and experience here.
Josh is serving our country in the U.S. Army and recently returned from deployment in Iraq. He's looking for a little work on the side to supplement his income. I'm sure so he can spoil his young bride Paige, whom Cindy and I also had the pleasure of meeting. You've got yourself an adorable firecracker there Josh.
I, without hesitation, recommend that if you are lucky enough to live within a reasonable commute, and need help with you car, get ahold of Josh. You will not be sorry.
So to begin with the header, it and the new flex pipe arrived well wrapped and protected. The box itself could have contained more "peanuts' to prevent those parts moving around during transport.
After unwrapping everything you wind up with the header, new flex pipe, two new gaskets with four new bolts for the flex to header connection / flex to exhaust connections and an instruction sheet. The instruction sheet gives some basic instructions but relies heavily upon you having access to a genuine Ford Focus Shop manual for specific instructions.
To begin the install you have to un-install the current exhaust manifold, which Ford refers to as simply the Catalytic converter. Yep, you are removing the cat with this install. I have a Magnaflow HF cat on my 2 1/2" Trubendz exhaust, so I'm not running naked.
I'm not going to try and do a full blown "how to" here. Just some highlights for you. If you purchase this kit and need access to the specific Ford Workshop Manual instructions for removing the stock system, PM me.
Josh was coming over to help me around 10am so I started about 9am to get some of the easy stuff out of the way. Before Josh arrived I had all the heatshield bolts off of the lower and upper shield, the exhaust unbolted from the flex pipe, the engine bracket for the cat removed and... that's about it I guess.
Josh arrived and after the introductions where out of the way, got right down to business. I believe after which point my total contribution was holding a hose out of his way at some point. [
] J/K, I helped - I did, I did so!
The old one came out without any major issues, just a lot of weird moves to get wrenches to where they needed to be.
We were able to reuse the stock manifold gasket and studs. The biggest issue was the lower O2 sensor. It was frozen in place and just did not want to move. After applying a little heat, working it back and forth, some WD-40 and a lot of patience it finally came out. However, the reason it didn't want to come out in the first place was a portion of the thread was melted. Josh did some magic with a small file and we were able to get a good seat in the header with that sensor.
We (Josh) had the header installed and everything re-connected in about 45 minutes, if that and the next thing I knew it was time to turn the key.
OK, Josh described it best. He said I had a tach smile. The higher the RPMs, the bigger my smile.
Here are the pictures I know you've been waiting for;
The stock system;
The F2 Header installed;
And from below;
And Josh himself;
This header, with my 2 1/2 Trubendz exhaust is on the load side. I'm still working on the exhaust to see where I get with the sound level but a resonator maybe in my near future.
Josh, thank you again for your help. I'm sure I'd still be trying to get the old one out at this point.
SOUND CLIPS ADDED, POST # 34
The stock system;
And from below;
And Josh himself;
