1 - 7 of 7 Posts
We have an extra hole for it and the lower cover has the clearance for it but why don't we use it?
Stupid question I know. Just wondering.
DTC P0606
I assume because Ford reasoned that any time you can cut manufacturing costs and mechanical complexity without affecting reliability or performance, you should do it. So they deleted the "extra" pulley as being engineering overkill.
C2H5OH
If you got the kit with the extra pulley you must use it.
The kit you got is for the ZX2.
If you set the upper pulley next to the one in the kit you'll see the one in the kit is slightly smaller. This is the reason for the second pulley. It takes up that extra slack in the belt.
So, use both pulleys or risk timing jumping from a loose belt.
Discussion Starter · #4 ·
I'll check the size on the 2 upper pulleys. When I did the belt on my car I didnt use the lower pulley and it has been fine. I'll use it on the motor I'm working on if the uppers are different. It does say "not used on all models" in the belt diagram though.
chucked mine too. I say a photo once where it was used on the zx2's and maybe contours?
1 - 7 of 7 Posts
