new to ford here-got a 2000 focus se 2.0 sohc- dropped a valve on drivers end of engine- replaced cylinder head and piston and rod(damaged journal by not using rubber hose to protect threads and the threads scratched the journal and after a hundred miles or so it started knocking) ... so i replaced crankshaft with rod and main bearings it came with using new torque wrench. rods were28ft and i forget was mains were... while engine was still in car, using all cleanliness and precautions such as using rubber hose to protect threads and oiled everything up during install. to prime oil pressure i took spark plugs out and cranked engine for 15 seconds a few times. when i started it, only one connecting rod knocked but after about 30seconds-a minute the other rods started knocking. whats going on?
i checked oil pressure and as soon as engine starts its jumps to 80psi.
ive read the oil goes from the block into the crank and then to the rods. are my main bearings too tight and not letting oil get into rods?
my email is linking to my cell so i will be impatiently waiting lol. why is my oil pressure so high? what is it supposed to be at idle?
