I haven't owned my focus very long (a few months) and she seems to have random problems pop up often. I'm hoping its just coincidence. Sticky caliper-just replaced all four calipers/hoses/rotors and flushed synthetic brake fluid. Then a week later PCV hose had a good sized gash in it. 4 hours later I have a new hose and very clean intake runners/flappers. Now... I have a rear main seal leak. First I assumed it was the oil pan (since I had it off for bsd and I don't trust gasket makers much) but there was zero sign of oil pan leaking and I could feel oil residue higher in the bellhousing. So, since I have to separate the engine and trans... I might as well replace the clutch and dmf (120K miles on original).
The cost is very similar to replace with a conventional solid piece flywheel+clutch as it would be to purchase a new dmf+clutch. I only have experience with lightened flywheels on sport bikes. I assume it will feel snappier in lower gears and decel will be more prominent. I also would expect to feel the powerstrokes (vibration) specifically at low rpm. What I want to know is how streetable the cars are to drive. On the interstate, 3000rpm is quite high so I don't see the engine "lugging" and pulsing. Is there any known or speculated durability issues? Will the lack of cushion increase wear on the drivetrain?
Also, if anyone has recommendations on a quality replacement RMS please speak up. Thanks!
