1 - 4 of 4 Posts
So today I did two things; I installed all three VF Engineering mounts and relocated my battery. It was when I did my battery and started the car up that it was VERY loud. At cruising, its so deep it makes my brain vibrate. It doesnt sound bad, its just really loud. Even at idle its just roaring. I did however give the idle trim screw an adjustment (FC Throttle Body) to try and raise the idle to 1100 but I cranked it back down just becuase at idle I cant sneak up on anyone. Also, when I let off the throttle, it doesnt declerate as it should and when I switch gears it goes up about 100-200 rpms (letting off the gas in between shifts). Is it really loud just becuase I basically reset my ecu and its just learning, or what!?
Tommorow Im installing my turbo and a STRAIGHT PIPE 3" exhaust. I just wanna make sure its something it cures itself via ECU learning cuz if not...LOUD will be at a whole new level...
Thanks in advance.
there's another turbo svtf in bel air, kick ass
1 - 4 of 4 Posts
