1 - 3 of 3 Posts
the pipe hanger bracket between the middle and rear muffler rusted off on my 2001 Focus SE.This is the bracket that pushes the exhuast up instead of a traditional hanging bracket. The pipes and mufflers are intact and still good. Is there any way to repair this without having to replace the exhaust components? Any help would be appreciated. Thanks in advance.
If there is enough material left on the pipes then any competent muffler shop should be able to weld a new bracket fairly inexpensively. But if the bracket is gone, you may get bad news in that when they try to weld, they blow a hole through the pipe as there really isn't anything left to weld to. in that case your looking new exhaust components.
Thanks for the suggestion, I will see if there are any after market bolt on products that may work
1 - 3 of 3 Posts
