1 - 2 of 2 Posts
Taciturn. Your turn.
Is the triangular header to cat gasket supposed to be a dual layer, or a 2-ply gasket in other words? Mine only has one layer and it leaks, I noticed that the cat to flex has two layers on it.
Im pretty sure the that gasket is just a single layer. Are you sure its leaking from there? if you are not sure where the leak is you can use seafoam and it will make white smoke go out your exhaust and where ever it is leaking.
1 - 2 of 2 Posts
