1 - 11 of 11 Posts
· Registered
ok here I go. I'm bought a short header and plannin n getting a hi flow cat with a 2.5" flex and I got the exhaust already.
Vs
The long tube svt heads with rt hi flow and a 2.5 flex.
Do u think that it will make a comparable improvment with up n tq?
I'm on my iPod so bare with me
-toe
· C2H5OH
get the svt long tube for the most gains.
X2
It has more to do with how the exhaust pulses are separated and combine than it does with the mass flow of the exhaust.
Think of it this way,
you fill you bath tub with water and use your hand to push the water around, your goal is to move the water around to disperse the heat evenly. Now your hand moves the same amount of water no matter how or where you start from. If you start from one end and push it to the other in roughly the center you will have ripples that meet and fight each other. if you work from an edge the water will work it's way around the edge and the ripples will not combat each other. hopefully you can visualize that, if not play in the tub next time you shower, lol.
Basically what I'm saying is the SVT is considered a tuned length header while the short ones are only done so to fit, not for maximum power. In a tuned header the exhaust pulses are still divided as they merge into one tube, each one pushes the first pulse and helps it keep momentum.
· Registered
Discussion Starter · #4 ·
so what ur saying is, the svt header are the perfect cause each one of tubes help each other out where vurse the shorty is all cramb into the tube all at once?
· Registered
^ yes thats what he is saying it would be like 1,000 people all coming out of 4 doors at once into 1 hallway as opposed to 1000 people coming out of 4 doors connected to 4 hallways to get out, theres not alot of pushing and shoving a fighting to get out
· Shot me 3 deer!!!
if you decide to go turbo, then you will waste ur money on a header setup!
· Shot me 3 deer!!!
true if you get them used, not true if you buy them new, but then you have no downtime!!
1 - 11 of 11 Posts
