i took the air filter off and spray the from the throttle body opening and aiming at the IAC hole. then i start the engine and everything seen fine but i got the great idea[bash] of taking the IAC out and really clean it good. got the IAC out with out any problem. I took it and spray it down with the TB cleaner, let it dry before installing it. after i put everything back(air filter, etc). i start the engine and the engine wont stay idle, it will just die if i dont feather the throttle, also for some reason the brake booster is not working b/c i dont have power brake even if i try to keep the engine idle by feather it. weird thing is, i was able to keep it in a rough idle if i unplug the MAF and take the air filer out from the TB but the brake booster is still out. please help. i guess there is a vacuum leak and possible one of the brake booster vacuum hose is out. Is there a vacuum hose around the TB area that i might have disconnect when i was try to get the IAC out?? if i can get it run by mid day tmw, i probably tow or slowly drive to my local shop and have them fix it as i really need the car for work. thanks for the help.
