Hi guys,
Two weeks ago I serviced my car, it is all explained step by step in this thread. My engine mount was leaking and vibrating in reverse gear, so I changed it for a NAPA one.
The problem is that my engine in vibrating more than before. It is making the noise in drive and neutral when the car is cold, and only in drive when the car is hot. This noise started after the service, so I am pretty much sure It has to be related to this part, because no other can cause it. When I jack the car when it is running, it stops.
I am thinking the NAPA mount might be a complete deception and piece of crap. I checked today the torque of the bolts and everything seemed to be correct.
Only problem now is that I am going to have to buy the tools to get this changed, because I don't want to use my friend's house anymore, I am overusing it already. So I want to make sure, it is this mount, and not the rear one (the one in driver's side), which I don't reach to see, I guess is under the ignition system.
When I was checking the noise today I noticed something that I don't know if it's normal. When changing gears from N to D, the whole engine swinged in the hood, and it was easy to notice. I never saw this before, because I didn't have someone to change gears for me. I can shoot a video of it, if necessary.
How bad can the vibration result to the engine? is NAPA going to refund a 60 dollars piece? I am already out of budget.
Thanks a lot
Thanks a lot
