1 - 7 of 7 Posts
ok so just recently my 2000 zx3 started sputtering from a start but it only does it from 1 - 2 k rpm what could be causing this very annoying problem?
Shot me 3 deer!!!
try cleaning ur maf!!
already done first thing i did
Make sure the plugs and wires are in good condition, also check the wiring leading into the coil, it broke on mine and gave me the same problem.
Discussion Starter #5 (Edited)
sweet thanks ill check that i know the plugs are brand new bastards was 19 bucks a plug so the better not be effed in the A after like maybe 2500
I washed my engine bay, and it did the same thing, because there was a couple inches of water under the plastic head cover so I think the plug wires were shorting. Anyways just dried it out and sprayed it with some WD, and it was good
That could be your problem right there, wires don't like to get wet.
1 - 7 of 7 Posts
