So I have been revamping my 2003 Cent focus with fswerks/vf supercharger. Once it gets put back together it's going to the Dyno for a retune. By my calculations it should produce about 10psi of boost at full song.
It's got about 221,000 on it. The car runs good but has a couple of oil leaks I need to fix. (Front crank, possible rear main, upper or lower oil pan)
I have the car on jackstands; the engine is sitting on jackstands hovering in the engine bay with all the engine mounts out and most of the hoses and electrical wiring disconnected. Now would be a great time to pull the engine and transmission(mtx75) to do anything I need to do to it.
The clutch is a ford racing center force factory clutch with about 50k miles driven hard but not abused.
How about the slave cyl? Change it?
What do you suggest I do?
A- full rebuild with bearings and rings with all gaskets
B- fresh gaskets with a carbon clean up and reseat the valves
C-do nothing it's a ZETEC U CAN KEEP RUNNING THAT BABY!
D- I suggest you do........
Thanks a ton for your input!
