1 - 4 of 4 Posts
Tempeaure condition indcates an engine overheat condition was deteced by the cylider head temperature sensor. How do you fix this
Engine coolant if full
Discussion Starter #2
Please help me anyone. My tech just charged me a lot of money to replace my transmission and the car runs very bad and now I having this issue please help
C2H5OH
Why not ask the tech?
Has it run bad from the time you got it back from having the transmission replaced? If so, first talk to the guy that did the work and see if he will help make it right. More than likely there is wiring that got disconnected or moved when the transmission was being worked on, causing your issues. I know when my Escort had work done we missed the O2 sensor at the cat and I had a CEL light and engine ran rough. If he's reputable he should help without charging you, as long as it ran right before he worked on it.
If you are getting a CEl, find out what the codes are and post back. You can have them scanned at a car parts place, usually for free, or need be there is a how-to for reading them throught the odometer display.
1 - 4 of 4 Posts
