1 - 20 of 61 Posts
GoKart and Me!!!
While working on the Focus today, a question came to me. I have a 2.0L Dtec and was wondering if a SVT engine cover would fit. I like the way the SVT cover looks along with the spark plug cover thingy. Would it work?
i dont think so. you would be better off getting a mazda 3 engine cover and modding it for ur car
BodyKits=PantiesDrop
if by ST cover you mean the metal valve cover then yes it will fit, however a valve cover and an engine cover are 2 different things, an engine cover is a decorative (usually plastic) cover that hides the ugly mess that is the engine, whereas a valve cover is the actual cover of the camshafts and valves and contains the oil. The 2.3L has a metal one whereas the 2.0L has a composite plastic valve cover
the SVT doesn't have an engine cover nor will its valve cover or coil cover fit the duratec, the Mazda3 cover will fit and many people have done it.
As said, the 2.3 and 2.0 duratec engine VALVE covers are interchangeable.
But honestly your better off just painting your original cover to your hearts desire, or maybe flat silver to match a stock 2.3's cover. My 2.3's metal valve cover is painted blue so...
And i may be wrong here, but wouldnt the 2.0's plastic cover weight less then the metal 2.3's? That might be something to consider even if it is only a couple of pounds.
i have an 07 st and my valve cover is not metal. it is the plastic one.
hmm really? well the aluminum one on mine stains very easily and requires a lot of upkeep to look nice unless you polish it, whereas the plastic one is, well, plastic, and is practically indestructible...
no that wouldn't fit mine, is that the mazda one?
i'm talking about the physical plastic cover on the mazda motor, as in this piece:
GoKart and Me!!!
Discussion Starter · #18 ·
The reason I was asking about this is that I've seen threads about wire tucks and thought about how the SVT valve cover has that narrow cover to cover up the spark plugs and make things look nice and neat. Willl the spark plug cover work with the ST cover?
1 - 20 of 61 Posts
