I have a 2003 Ford Focus 2.0 SPI. I put a new timing belt, head gasket, and other things on this car. The question I have is when I accelerate the engine bogs down and has no power and has a random miss. I suspected many things and changed a bunch of stuff according to reading other posts. The issue is I removed the intake manifold and as I was removing the two 8mm bolts on the top of the intake manifold in the center, engine coolant started seeping up out of the gasket. I took the manifold off and there was engine coolant in what would look to be the number two intake/exhaust ports on the cylinder head. There is no engine coolant in the actual cylinder and no engine coolant in the crankcase. I am suspecting a bad intake manifold gasket and engine coolant was leaking from the water jacket and getting into the ports on the cylinder head?? Which would lead to the vacuum leak from the bad gasket... Is there supposed to be any liquid whatsoever in those ports? and since there already is what do I do to remove the coolant?
Also there was no engine coolant in the other intake/exhaust ports and the number two port is closest to the water jacket. I could really use some help. I need to get this thing back on the road. Thank you.
