1 - 4 of 4 Posts
Alright so after searching the archives I could not find anything that exactly matched my problem with the SVT motor. Basically when the motor is idling i hear a chattering noise or ticking, I realize this could be a valve problem. Is there anything else it could be?? How concerned should I be? I know I have to get the timing belt changed I'm at 90K and I was changed at 35k by the previous owner (dont know why they did it so soon). Also the noise speeds up as my rpm's go up and it finally gets to the point where my motor drowns it out.
Seems like the svt is starting to make all sorts of noises all of a sudden [smackbum]
Dragon Warrior
what yo crew said. and My SVT has always been noisy. do you have a camera that takes video with sound? if so post up a Video of it so we can listen. but my SVT has always ticked. and i bought it new.
one other thing to go off of what Yo Crew said. push in the clutch adn see if it goes away. if it does you have the clutch chatter issue if not then it is something else or it is just the sound of the solid lifter buckets of the valve train. just a sound all the SVTs make.
1 - 4 of 4 Posts
