1 - 15 of 15 Posts
I was opening up the hood of my FF the other day for the first time since purchase (I know, don't laugh) and I noticed two things:
1. There is some sort of matte/foam/material on the top of the inside hood (when opened up) that I assume is used as sound dampening material.
2. There is no engine cover.
Based on what I've been reading, I can't tell if adding on the engine block cover will further dampen sound or not. Some have said that it will, whereas others have said that it amplifies sound. I don't know which to believe.
For those that have (or have not) added an engine cover, why or why haven't you?
The cover has sound deadening material on the underside, so I would think it quiets things down a bit. I'm seriously thinking about adding one to my Focus, not so much for reduced sound but for the looks.
Jetsetter
It dampens the sound for sure. and if anything it looks 100X better than without.
Moved to the Duratec TiVCT performance section
I'm a fan of being able to see everything under the hood easily, so an engine cover wouldn't be worth it for me.
They pop right off with no tools.
Yeah I know, but I would not rather have something to have to pop off everytime I look under the hood or if I'm looking at something else in the engine bay I can instantly see if anything is going on with that part of the engine.
If you are running any kind of CAI the engine cover cuts down a lot of the sound.
Works for me !
it does make the engine bay look a lot better IMO, heres mine.
Yea! And these are easily paintable so you can customize it for yourself
I live in south Florida and noticed these things get HOT! I also wanted to hear the motor more so I removed the sound deadening material and added high heat reflective tape (it worked well on my 1000rr when I noticed the inside fairing bubbling by the exhaust). I'm going to put it back on during the winter months and eventually leave it on year round once I install a 180 thermostat. It gets heat soaked if you leave it on for a track day too.
1 - 15 of 15 Posts
