I know there are threads out there that address this but I wanted to make something with a title that would show up in future searches.
To enable global closing I used this video for a guide.
In my 2012 titanium I needed to do this procedure with the car off. When the car was on the process stalled at 80% (and scared the crap out of me)
I used option 3 as the video stated for the config change but it doesn't open/close your moonroof no matter the setting.
The bluetooth module I used was an ELM 327 Mini Interface which is currently $11 from Amazon at this link.
http://amzn.com/B008U1MOM8
Add it to windows using the following guide
http://www.totalcardiagnostics.com/...stall-elm327-bluetooth-obd-scanner-on-windows
For this specific ELM the pairing code is 1234
Once the process was completed I needed to clear out the Diagnostic Trouble Codes that were created as a result of writing to the system. I was able to do this with the FORScan app from the following site.
http://forscan.org/
The process of clearing the DTC codes involves connecting to your ELM, navigating to the DTC section of the app, and choosing the button at the bottom of the screen that clears the codes.
Now you're 100% done.
http://forscan.org/
