Recently i had a new wire harness put on the battery because of some corrosion issues and with that came a new battery. Now I have no control over my rear wiper and rear defrost. Also the front wiper cannot go into intermittent which is about the same speed as the front wiper intermittent. I have checked and rechecked the fuses inside the car for these components. The wiper in the front will run at normal speed and full speed and the fluid works for both front and rear. The rear wiper does not turn on at all. I went back to the dealer that replaced the harness for the battery and said it was the wiper switch inside the car. I just installed a new switch in the car and the intermittent front nor rear wiper work. Any Ideas????? thanks
-Matt-
-Matt-
