Ladies and Gentlemen,
I have recently purchased this vehicle and here are the following codes that Autozone gave me from the check engine light:
P0102 - Probable Cause - Intake Air Leak Duke tube loose or damaged, Open or short circuit, IP signal error, Faulty MAF/VAF sensor, Open or short circuit condition
P0113 - Probable Cause - Faulty IAT sensor, Poor electrical connection, Open or short circuit condition
P1506 - Probable Cause - Failed IAC valve, Engine Vacuum leak
P0401 - Probable Cause - Blocked Passage on EGR system, Failed EGR valve, EGR Solenoid faulty, Failed EGR pressure sensor, Failed EGR position sensor
P0460 - Probable Cause - Failed fuel level sending unit
P0442 - Probable Cause - Defective or loose fuel cap, EVAP canister or hose cracked-not connected, Purge or vent solenoid defective, Vacuum leak at engine
P0135 - Probable Cause - Oxygen sensor, Poor connection at oxygen sensor, check circuit fuse
P0141 - Probable Cause - Faulty H02512 (Bank 1 Sensor 2), poor connection at Oxygen sensor, check circuit fuse
Now I don't know where to start and I am asking for some help on where I need to start at - thats a lot of stuff to do!!!! ANY SUGGESTIONS WOULD BE GREATLY APPRECIATED!!!!!
