Have a 06 zx5 that has developed a battery drain issue when the car sits. Seems to be find as long as driven daily, but if it sits for over a day sometimes battery won't have enough juice to turn starter over. I say sometimes cause there are times when car has sat for 2-3 days and started just fine. Batt is around 3 months old and i've had it tested at two different places, passed as good both times.
Testing with my meter when car will start, bat sits around 12.8v with key off. With car running is at 14v with nothing on, around 13.2 with all accessories and lights on. Connections appear to be good and no cel or bat lights staying on in dash . I have checked bat terminals with meter during the times when car would'nt start and voltage would show around 7.5 to 9 volts.
Next i hooked meter in series on neg side of bat to look for parasitic draw. Here's where i'am not sure whats going on. When i first connect meter thereby completing the circut, i get a .89 amp draw but just for a few seconds then it quickly drops to .01 amp and stays there. (This on the 10 amp scale on meter.) Admittedly i'am not real knowledgable with more modern cars loaded with electronics to know if what my meter is showing is normal for this model. I did go ahead and started pulling fuses from engine compartment box to see if anything changed on my readings, no effect.
Disconnected main hot from alternator which also had no effect on meter readings. However if i connected a test light inbetween main hot and alternator the light will flicker on and off which on a older car would indicate and open circut/ bad diode in the alt. On the focus though it is my understanding the the alternator is connected to the pcm so not sure if this would effect the test light method in anyway.
Where to go from here? Anyone with opinion on whats going on or what i should check out next? I just know something an't right, bat should'nt go flat after sitting just a few days and do it radomly to boot.
flames
flames
