1 - 3 of 3 Posts
Zzzykeyah!!!!!!
will it fit a 2007 and how much of a difference does it make.
Adam
No. 2000-05.
Well. I checked the Eibach website against the part #'s of many diff vendors. This kit can be used from 00-07 (Note: I could not verify 08-09 to my satisfaction. but I think it is the same part numbers as well).
Eibach website has Part# 3588.320 for the F/R Kit. Here are the application notes for each bar in this kit.
Eibach Anti-Roll Kit
Front
3588.310 - Application Notes
00-05 Focus, 3-Door & 4-Door (Incl. LX, SE, ZTS, ZX3 & Sports Models) - (Front: 22mm) (as)
00-05 Focus, 5-Door - (Front: 22mm) (as)
00-05 Focus, Wagon, SE - (Front: 22mm) (as)
06-07 Focus, 3-Door, 4-Door & 5-Door (Incl. LX, SE, ZTS, ZX3 & Sports Models) - (Front: 22mm) (as)
Rear
EIB3588312 / 3588.312 - Application Notes
00-05 Focus, 3-Door & 4-Door (Incl. LX, SE, ZTS, ZX3 & Sports Models) - (Rear: 25mm )(as)
00-05 Focus, 5-Door - (Rear: 25mm )(as)
00-05 Focus, Wagon, SE - (Rear: 25mm )(as)
06-07 Focus, 3-Door, 4-Door & 5-Door (Incl. LX, SE, ZTS, ZX3 & Sports Models) - (Rear: 25mm )(as)
Eibach uses 'Energy Suspension' bushings (see note). Of which there seems to be a fitment issue. Primarily on the front bar. HELLBOUND is currently talking with Eibach regarding this. Hopefully he will be able to provide a resolution on the near future. FYI: Prothane also appears to have the proper sized bushings. Prothane also offers a 'greasable' bushing. I have no application notes however for there offerings. There is also a 'reinforced' rear LCA available from Ford to address a potential breakage issue when using large bars. (Ref: b16sir1991 & Auto-X-ZTS in thread 'Wheels, Tires, Brakes & Suspension / 'Hard Cornering: It could be better'). Auto-X-ZTS also provided pics of broken rear LCA in thread 'STEEDA 28mm rear sway'.
I would recommend you review both threads if you have not as they contain a lot of good info pertinent to your question. Good luck with it. [target]
Note: 1 vendor stated use of 'Energy Suspension' bushings. Part number cross check pending.
1 - 3 of 3 Posts
