1 - 9 of 9 Posts
Had the Eibach Pro Kit springs and Koni Sport dampers installed on my son's 2013 SE. Mild lowering less than an inch. Set the Konis on softest damping setting. Added a Steeda RSB. Corners like a go-kart now!
Sent from my SM-G973U using Tapatalk
  • Like
Reactions: nyuk98gt
Discussion Starter #2
After a few days of driving it. Drives great. Konis on softest is perfect...no need for any stiffer dampning for a daily.
Do you have any links to the items? At some point in the future I’ll be upgrading my suspension and I’d like something that will help my car handle a little bit better without sacrificing too much softness on the bumps.
Discussion Starter #4 (Edited)
Konis and Eibach kit - tirerack.com
Steeda RSB - steeda.com
I'm sure you can find them.
Before and after. V. mild lowering - I'm mad that I didn't grab a before measurement but Eibach says 0.8"...I'd say that looks about right. Definately not more than an inch which is perfect.
307387
Thanks for your time man. I know this will look good. Did you install them yourself or have someone do it? How much did installation run you?
Discussion Starter #9
I had them installed. I paid $500 including alignment and some misc. parts and new mounts/bearings. I got the Koni/Eibach cup kit from Tirerack for ~$850.
1 - 9 of 9 Posts
