Hi all,
My focus was losing power when up to temperature and I got the following error codes using Forscan:
P1412-60 - EGR valve frozen
P0490-20 - EGR Circuit high
P042F-40 - EGR Stuck closed
P042F-C - EGR stuck closed
So, I brought it to the garage and they fitted a new EGR valve - Haas I believe.
A few days later on my long trip to work, when the car was up to full temperature after about 10km, I lost power again. No power boost, as if the turbo is not kicking in.
Switching off the ignition and immediately restarting the car seems to temporarily fix the problem. However, using Forscan I noticed more error codes:
P042F-20 - EGR stuck closed
P0490-20 - EGR circuit high
P042F-P - EGR switch closed
So, using Forscan, I reset the EGR learned values and temperature setting.
Another test drive (10km and up to full engine temperature) and the same thing happened.
Assuming the EGR valve is now good, does anyone have a clue what might be the next thing to look at?
Thanks a million
Thanks a million
