1 - 5 of 5 Posts
Would it be possible to swap out the ecu of a SVT from a 2004 zed0 to a 2003 yfr0, and still have everything work? Will this screw up mileage or anything?
I would probably just stay with the stock ecu and flash a tune to it. The svt doesn't have a egr and has vvt and it would probably mess up once it started an not run right since the svt motor has different a/f calibrations.
I'm pretty sure you would have all sorts of communication issues... the reflash is a better idea.
Get in touch with V6focus at focussalvage.com he is the man when it comes to ECU's...He keeps several in stock and can swapthem if need be.
FF Cleaning Squad
Why do you want to swap the ECU?
Unless you drop the SVT motor in there it will not work right.
1 - 5 of 5 Posts
