1 - 13 of 13 Posts
pwned
Hi guys, I'm going to install my SRI this weekend and was reading the manual about the battery. It states after performance altering parts are installed, the ECU must re-calibrate idling and fuel specifications, how long do I drive for before this stuff is calibrated? Should it be city driving or highway also?
Thanks in advance!
As long as you disconnect the neg battery cable you will be fine just drive like normal after.
pwned
OK, I guess the Ford manual is being over-excessive to protect themselves, they say you gotta drive the car for about 10 mins before it's calibrated lol
pwned
Just want to give a thanks to everybody for all their information. Installed the SRI and everything is great, I really didn't expect such a sound difference in the mid RPM range. I'm very pleased with this!!
Force-Powered Focus
yeah, the steeda is really loud up front!
Fear the TurboSnail!
You don't even have to unhoock it for 10 minutes. Only a couple. Basicly unhook it. Then rehook it a minute or two later. Check your tripmeter. If that is reset your good to go.
Anyone know how to get rid of the intake whistle you get after installing the SRI? I checked all the hose clamps and they're tight.
that whistle is normal, it's just the air rushing past the tb plate. Nothing you can really do about it (except from what I hear that buying a aftermarket tb quiets it)
That whistle is from your throttle body cracking open at certain rpms.... Its nothing to worry about. You can just hear it now because of more velocity from the greater air supply. Buy an aftermarket tb like c-f-m 67mm and it will cancel out that whistle.... Or you can just buy a header and drown everything out...... kiff.... loud noises!
Force-Powered Focus
i have heard that the 67mm will get rid of the whistle, but never heard on the 65mm...makes me wonder, cuz the stock tb has that little lip on it. it is 63, but u can bore it out to 65. so i wonder if u would still have it, or if that lip disappearing gets rid of it.
and that whistle usually should occur around 3k.
1 - 13 of 13 Posts
