1 - 12 of 12 Posts
Discussion Starter #2
I was hoping to post a nice written out post, but my Post count is not high enough to post Image Links.
I will mess around on the forums and hopefully report back with a nice first Post.
Ill start by saying I work at Panda Motorworks: We specialize in Ford Performance Vehicles and have really developed the EcoBoost cars. Focus RS/ST, Fiesta ST, Mustang, Raptor, etc. I had a Fiesta ST and had a blast with that. My girlfriend bought a Miata to learn to drive stick and to get into Autox with me. Chris- Panda's owner- and I went to go get her 91' in Indiana. Cassie was out of town and she let me drive the car at its first autox. Stock everything and winter 185 series tires, I went out and had a blast. I couldnt keep it straight andI fell in love. Right around the same time, my first project vehicle was stolen from outside my home. It was a passed down 89' S10 that came from my uncle. A Junkyard, twin turbo, SBC 350 and a T5. It was fun and I was heart broken when it was stolen. Cassie saw how much I missed the truck and how much I loved the Miata. A month later, she surprised me on my Birthday with a 90' Miata shell. That is where this project begins.
I had talked about wanting to swap a 2.0 EcoBoost into something for some time. The chance was finally hear. We have a special engine where we use the 2.3 rotating assembly and head and put it in a 2.0 Closed deck block. The setup will make 750whp but I am just shooting for 600whp. The engine is nice because out of boost, it is a tame little 4cyl, but get on the throttle and once the turbo lights up, you have flat power from 3700-7000rpm. It was a logical choice. All aluminum engine, big power, keep the weight down, and have something fierce on the street and strip.
Here are some Engine Specs:
11.5:1 Compression
88mm Pistons
94mm Stroke
Weisco Pistons
Callies Compstar Rods
2.3 Factory Forged Crank
King Racing Bearings
ARP Hardware
2.3 EcoBoost Twinscroll head
Supertech Head Gasket
Supertech 77lb Springs and billet retainers
Radium Aux Fuel Rail w/ 50lb Injectors
Radium PCV Breather Plate and catch cans
Here are some Images from our S3 Magazine Article for the engine build:
So I started tearing down the shell. First thing I did was make mounts for a 8.8 swap in the rear end. I had a 8.8 in the S10 and the familiar locking of the clutch packs and controlled power delivery had me sold... oh and the strength. a 3.27 LSD from a Supercoupe T-bird and I started welding in the mounts. I found all the dimensions for the mounts online and made them in my free time using scrap steel. Got it all lined up and laid down some beads. While I had the subframe out of the car, I installed Poly Bushings in the rear control arms and hubs. I figured now would be the time to try and reduce any chance for wheel hop.
Heres the images I used to make mine
After the Rear Subframe was in, I decided it was time to update the front as well. Again, all new poly bushings for all the control arms. Cleaned everything and threw a coat of paint on Black Engine enamel on the arms and reassembled everything. While I was doing everything, I added NB Brakes front and rear to help in the future of slowing down.
I invited some friends over for a weekend in the shop. I ordered a M5OD trans from a local salvage yard and bolted it up to my engine core. A night and lots of beer later, we had our engine and trans mounted in the car. A little more cutting that any of use expected, but the engine was in. To our surprise, the front of the timing cover is completely behind the center line of the front wheels. I guess we have ourselves a mid-engine drag car. A pretty large section of the firewall was needed to be recessed for the HPFP on the EcoBoost and to allow the oil pan to be low and sit back. Here are some pictures of the mounts and firewall completion.
After motor mounts were finished up, I sent the car off to Andy Seehausen. Andy builds cages for FD cars and other motorsport. He has worked for Worthhouse, David Mesker, and many more. I decided I wanted to be safe so getting a 6pt cage was a must. After dropping the car off, I drove to Asheville NC for my summer internship at Eaton. Thats the first update of this build. Im picking the car up Mid August and the engine build process begins.
Parts have been rolling in this summer thanks to some great sponsors. A lot goes into a build like this and many people have given knowledge, parts, support, and much more to help get this project rolling.
So far I want to thank the sponsors that have supported this build.
Mishimoto
Supertech Performance
Callies Performance
Terry's Machine Shop
Radium Engineering
Fuelab
Fab9
Cosmis Racing Wheels
Panda Motorworks
ZFab
DaVinci Performance
Here are some other pictures I feel relevant to the build as Cassie has been building her car and I got a new Daily along the way:
Here is my other project/race car:
And my First EcoBoost swap:
Ill be updating with more pictures.
Is this is a 2.0 or 2.3 in a Miata..... God bless you.
Its a Hybrid. 2.0 Block, 2.3 Head and rotating assembly. 11.5: comp, Gen 2 Precision 6062, and some Panda Tuning should help it out just fine haha.
I have a feeling this 25 post count may take a while.
w/ my magic bag
Just jump in to other threads & you'll be there.....
Discussion Starter #10
Rather big update:
The car is back in my possession!!! And BOY! DID THE CAGE TURN OUT SEXY OR WHAT!
Andy did a great job on the cage. Top is still functional and all. Check out the fitment of the door bars against the doors. Couldnt be happier with the final product.
Untitled by Mason McGavock, on Flickr
To keep the cage from rusting, I went straight to work on painting the interior. Cleaned 29 years of dirt, dust, hair, french fries, etc from the car and went to town with some red scotch brite on the floors, firewall, cage, etc.
Bed liner on the firewall and trans tunnel. Followed up with primer on the cage and floors.
So it is all primered now. Next step is painting the cage & interior with final color, painting the trunk, and engine bay. Another couple days and it will be finished.
While Ive been working on that, my Engine Block has been at Terry's Machine Shop. Check out this video we put together of the beginning stages of our engine builds at Panda:
Once that is back, more painting- this is kinda getting redundant lol- and then engine assembly.
Wont be terribly long though before this project comes together and is running.
Check out our other toy:
Discussion Starter #11
Not much of an update, just been slaving away on wiring. Luckily that seems to be coming to an end. Ill attach my youtube channel so you guys can keep up to date with both the EcoYata and my other projects ive been working on. Just finished painting my girlfriends miata. CTSV Glacier White Metallic edition Pearl.
Anyway, treadstone TR1045 intercooler and their largest oil cooler just got delivered today along with a pretty slick oil filter housing and oil thermostat for the cooler. A bunch of the parts are just awaiting to be installed once wiring is finished. Injectors, Injector controllers, Fuelab Fuel System, Cosmis Racing Wheels, Silvers NA Coilovers, Action Clutch, etc.
1 - 12 of 12 Posts
