Dual scroll turbochargers are on the market- that's the same style as the eco-boost. The 2012 is a little too new to have been investigated by aftermarket companies for boosting. You might have a wait a couple of years. For example, turbocharging requires much more fuel than normally aspirated engines, so you might need new injectors. As far as I know, nobody has researched the capabilities of the new direct injectors. Due to the high pressure, it might be possible not have to change injectors. That makes things a bit easier, but I don't think anyone is going to produce a turbo kit where you can put it on a totally stock engine because the compression ratio is 12:1. Even with direct injectors, it is most likely not possible to boost an engine with high compression like that. That means you'll need new pistons with a lower compression ratio.
I'm just scraping the surface, but you see why it might be a while before there is a turbo kit for these engines.
It's not the topic for Technical Chat anyway. Ford Focus Technical Chat is for technical discussions relating to general maintenance, electrical issues, engine trouble, and recalls. Basically that means repairs. Your question might be better answered in the Ecoboost and Forced Induction Chat Forum which is dedicated to turbocharging and turbocharged vehicles. Those guys in there like 1TurboFocus, 03OrangeSVT, and others have lots of experience with turbocharging.
