1 - 8 of 8 Posts
FF Affiliate
Testing for a Vac leak , I have a bunch of people ask whats a easy way to find a Vac leak , I like Smoke Testing using a Cigar , I find a Vac line going to the intake , blow 3-5 big mouthfuls ( I dont in hail lol ) into the intake manifold through a Vac line, with it dark ( smoke shows best in the dark with a light ) and with a good shop light or good flash light and look for smoke , you will be able to narrow down where the smoke is coming from with 1-2 more mouthfuls of smoke , This works very easy , quick and cheap
I'm wondering where specifically on the MK3 2.0 would be good for this. Also thunk I need to send you a data log. Every time I start my car lately I feel a noticeable blip in the RPM that feels like a rough idle. I get that the car is warming up but this doesn't quite feel right to me. I was also idling one time and just felt the car shake like maybe a misfire.
My MK3 acts odd every once in a while making me think something is on its way out. Not sure if maybe a fuel pump or what. Was also a couple times after I got my new TCM where it felt like it didn't want to shift up. That hasn't happened in a long while tho. Was wondering if it was tied to the engine.
Sent from my Pixel 3a XL using Tapatalk
FF Affiliate
You can remove the Vac that goes to the EVAP and use that hole with a Vac line , Have you done the EVAP recall yet ?
Ah you mean disconnect the purge valve and use that line? I did the recall. It was after I replaced the purge valve myself. Got the new software.
FF Affiliate
You can remove the EVAP hose where it connects into the Intake or the brake booster hose same thing
1 - 8 of 8 Posts
